Modeling Dynamic/Parametric Quantity of holes
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am designing woodworking workbenches for a class full of students who will want different Dog Hole patterns in their bench tops. I will be CNC machining the 3/4" holes to their custom rectangular patterns. I have created the variables/parameters to allow them to spec edge distances, number of holes, etc. and all the modeling is going well until I changed the quantity of holes in the configured design. The Hole command only remembers the original number of point/hole locations selected when I created it, so if additional holes or fewer hole locations (points) are created by the change to the quantity of holes parametrically, the hole command errors out and I need to re-select the points created on the preceding sketch by the rectangular pattern that uses the parameters to lay out the pattern.
So my question is...is there a way to have the hole command select all the points on the sketch plane similar to how in the CAM command for drilling holes, it can be instructed to selects all holes even if the quantity changes?
