Hi!
I separated this part into two components, because I thought the division between both hindered the creation of the lattice. When I split the part, I could easily create a volumetric lattice in the right component. In the left part, however, there seems to be a problem: no matter which lattice I select (gyroid, etc) or which lattice size I select, only a small sphere is created. are the bore holes problematic? If so, the problem should be solved with a sufficiently small lattcice size, should'nt it?
Does somebody else have a potential cause or solution?
