Volumetric Lattice does not work
feidhlim_gardianGMXBH
Hi!
I separated this part into two components, because I thought the division between both hindered the creation of the lattice. When I split the part, I could easily create a volumetric lattice in the right component. In the left part, however, there seems to be a problem: no matter which lattice I select (gyroid, etc) or which lattice size I select, only a small sphere is created. are the bore holes problematic? If so, the problem should be solved with a sufficiently small lattcice size, should'nt it?
Does somebody else have a potential cause or solution?
g-andresen
Please share the file.
File > export > save as f3d on local drive  > attach to post
günther
It works now! I had to remove one of the intersecting bore holes and will add them after printing. Thanks anyway!
1995masg
Community Visitor
Community Visitor
Hi, I need some help
I tried to use the Lattice tool to this body but when I use it the body turns clearly and i can´t see the cell size and other parameters.
