Is it possible to create a Form Mill yet?
chrisevrard
chrisevrard
Hey All,
I have tried the steps I found in this post:
https://forums.autodesk.com/t5/fusion-design-validate-document/creating-a-form-mill-issue/td-p/54282...
But cannot successfully create a form mill. The option to Import doesn't seem to be available.
Am I missing something?
Here is my form tool:
It is basically a drill I need to use in a lathe component.
Thanks for any info,
Chris E.
HughesTooling
You only need to create a sketch then in the manufacture workspace use Form Mill on the manage menu to import into the current document's tool library.
Mark Hughes
Owner, Hughes Tooling
chrisevrard
That did it!
Thank you very much.
Chris E.
