@ClintBrown3D Is there any way to add angular dimension more than 180°? Similar to baseline dimensions but for angles.
I'd like to be able to dimension then next 2 of 216° and 288°. I need to set some parts up on a machine using a round table type setup on an EDM machine. I also need to set the angle the machine with cut so although I can work these out it would help if I could actually have the angles on the drawing. This is part of a 2 cavity mould and the other side is rotated 180° so it's going to be easy to get confused if I need to work this out rather than have it on the drawing.
Mark Hughes
Owner, Hughes Tooling
