MockUp UI Fusion360 after Update of 11th June 2018
- Mute
- Permalink
- Report
Autodesk Fusion 360 Team,
Hello again.
Thanks to the creative impulse proposed by @Anonymous, I have decided to create Mockups of how I imagine that the Fusion360 UI could be seen, taking into account my comments in the previous post (https://forums.autodesk.com/t5/fusion-360-design-validate/feedback-about-update-11th-june-2018/m-p/8063652)
Back to gray: I know that it is a step backwards from the current evolution, but considering the colour balance and the visual cleanliness, I consider that a monochromatic interface is the best option.
- Data Panel integrated to Tab bar: Reducing space between bars and granting a multifunction to them, I think that the Data PanelIcon can be housed to the left of the title tabs. Obviously when you click on the Data Panelicon, you look for a file that you want to open, so it makes sense to be at the same hierarchical level as the tabs. Now ... many will be asking "And where are the icons ofSave, New File, Redo, Undo?" That's next.
- Use the existing menus: Many commands are repeated and scattered throughout the interface. Mainly Save, Save as, New File, Redo, Undo, are already in the menus Fileand Edit, so I suggest that to avoid confusion and avoid repetition. The user simply enters these menus to access these commands.
- Multi-environments bar: In order to maintain a simple and clear interface, I propose to have the different work environments located in 8 cells, so the user does not have to open a drop-down list that overlaps the Browser, and can have access to all the environments quickly. The toolbar with the commands will be the one that will change in each environment, showing the particular tools of each of them (as already happens)
More space for personal commands: Deploying a full toolbar (not floating as it is currently) allows you to add more action commands that are much more accessible than the current drop-down lists. The toolbar is also a little smaller than the current one, with icons and smaller text.
- Anchored browser: A browser anchored under the toolbar and auto-adaptable to the name of each element would be a good contribution. Nothing that is floating (bars, menus, etc.) facilitates a clean work and without distractions.
- The turn of the arrow up: This arrow allows you to compress/hide the tab bar and gain even more space on the screen. By clicking on the Viewmenu, the bar can be displayed again if necessary. To access the Data Panelyou could simply use the Keyboard Shortcut (Shift + Cmd + P) and to jump from project to project Cmd + 1,2,3.
- Viewcube smaller: As in Meshmixerand AutoCad, the Viewcubecan be reduced in size and opacity. In case the user needs it, when the mouse is moved closer, the ViewCubereturns to an opacity of 100%. When you remove the mouse from it, it goes back to opaque 50%.
Bonus track: Considering that all professional programs are offering the option of a dark UI (or simply implement in their only UI) I also offer the possibility of creating the long-awaited and necessary dark interface of Fusion360.
I know that the model does not look so good, but in my MockUp it was already a bit difficult to detailI hope that some of these ideas can be used for a next update of Fusion 360. To my way of viewing are simple (and perhaps for some "unnecessary and not important") modifications, but that to my way of seeing, are those same details that define the user's experience with the program and its daily use.
Many thanks.
Kind Regards,
Rafael Mongelos
