working with imported DXF
malcolm.burnage
Message 1 of 1
malcolm.burnage
Hi
I have imported a DXF file of a model car that i want to make in Plywood for a child, size of sketch parts imported 600mmx1200mm.
I have no issues with the import or the scale, the only thing i would like to solve is the ''change' of scale.
Due to the nature of ply thickness variation i do need to change the scale of the drawing, the problem i seem to get is when i select all the parts in the sketch to scale it takes an eternal age to select them and then even longer to change it, even if only .5mm. I grant there are a lot of parts but i do not see how to resolve that as it comes from a dxf supplied by the manufacturer.
Am i missing a change to the import before working on it?
thanks Malc
Replies (0)
