mirror error
mirror error
Message 1 of 12
mirror error
The assumption of the  mirror function it should let to copy also faces. Then ,why the attempt of the using mirror funcion with faces  usually does generate error ?. I tried it many times.
Replies (11)
Message 2 of 12
ADSKDJW4
Hello ludwika85,
I have tried some simple designs to where it appears the mirror faces would need to be mirrored and the result of the new faces would need to be on the body of the original model. I am also seeing these errors when mirroring faces and cannot come up with an example to show you a mirrored mace. Can you attach a sample model to where you need to do this and I can log this issue to the development team.
Best Regards,
Don Warner
Message 3 of 12
Hi
The model is attached  below as *.igs file
Message 4 of 12
ADSKDJW4
Hello ludwika85,
I have downloaded the Iges file. Can you tell me exactly what you’re trying to mirror? Possibly show me in a couple of screen shots, attach to a post reply? I would like to see if I can get you an answer on this.
Best Regards,
Don Warner
Message 5 of 12
Hi Don
The YT presentation is attached. https://youtu.be/66nXHH_C_XA
Some for explain :
System : WIN 8,1 64bit polish version
In polish "Brak odpowiedzi" means "Not response"
After "OK"  in the mirror window AF360 is crashes for ever . The Task Menager helps only.
Sorry, but remember in Eurpe we have now 9.30 PM time.
 Best Regards
Message 6 of 12
bob_holland
Autodesk Support
Autodesk Support
ludwika85,
With your IGES file we only get one body in Fusion.
All I see there is a face.
Can you please share your model with me.
bob dot holland at autodesk dot com.
Thank you.
Bob Holland
Autodesk Product Support
Message 7 of 12
Hi Bob
You have shared the whole project .You can find this model in the folder which is named "router_plane"
Regards
Message 8 of 12
bob_holland
Autodesk Support
Autodesk Support
ludwika85,
I went back to your source IGES file and I am experiencing the same issue.
I will be asking our development staff to take a look at this.
Thank you.
Bob Holland
Message 9 of 12
bob_holland
Autodesk Support
Autodesk Support
@ludwika85,
I played with this a little more and found that if I do a 0 offset of the face and turn it into a body, it sill allow me to mirror the body.
I have attached a screencast of the operation.
FYI
Bob Holland
Message 10 of 12
Sorry , but where is this screencast. Did you attached it to the post ? I can't find it.
Message 11 of 12
bob_holland
Autodesk Support
Autodesk Support
ludwika85,
I am sorry that the attachment was stripped out.
I will embed it:
Bob Holland
Message 12 of 12
Thanks Bob. A little complicated, but it is a good solution, the more the new face could stand alone, basic face (after offset) could be erased
