Mirror a mesh object
Message 1 of 16
I have an .stl file that i want to Mirror. its a Surf fin and i want to make a pair. i have one side attached here.. how can i make the opposite side one in Fusion360?. i tried the mirror options but cannot ,http://a360.co/2a7Gk9g
Replies (15)
Message 2 of 16
masa.minohara
Hi Dave,
Welcome to Fusion community! Mirroring mesh bodies is not supported so could you try going to Model workspace and right-clicking on the mesh body in the browser, and then selecting "Mesh to BRep" command and mirror a solid body?
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
Message 3 of 16
Ok i Can Change to Brep.. but then how do i mirror the solid Body?
sorry i couldn't find that solution..
Message 4 of 16
TrippyLighting
Message 5 of 16
Thanks.. but.. i get this problem/error then..
Message 6 of 16
TrippyLighting
Could you export your model and attach it as a .f3d file ?
Message 7 of 16
i just got it to work...
 now stumbling my way thru seeing how to machine it.. I'm trying to change the material to plywood..
Message 8 of 16
semiconducted
When I select a mesh body in the tree and right click, I see no such "Mesh to BRep" command in the list.
Any idea why?
Message 9 of 16
vinc.beaulieu
To Convert Mesh to BRep, you must first Deactivate the Capture Design History.
Screen Shot 2020-10-22 at 12.40.14.png Screen Shot 2020-10-22 at 12.40.20.png
Then on right click, of the mesh body, you should be able to convert Mesh to BRep.
Screen Shot 2020-10-22 at 12.41.01.png Screen Shot 2020-10-22 at 12.44.33.png
This is using version 2.0.9011 on Mac.
Message 10 of 16
TrippyLighting
That is incorrect!
With the design history enabled you to create a base feature and while in the base feature you can convert the mesh to a BRep.
Message 11 of 16
vinc.beaulieu
To Mirror a Body, select the body, then in the Create drop-down menu select Mirror.
Screen Shot 2020-10-22 at 12.53.34.png Screen Shot 2020-10-22 at 12.53.53.png
Select a Plane, Choose the Operation, then select OK.
Screen Shot 2020-10-22 at 12.54.27.png Screen Shot 2020-10-22 at 12.55.52.png
Message 12 of 16
vinc.beaulieu
Can you visually demonstrate how?
I couldn't arrive to the Mesh to BRep otherwise.
Message 13 of 16
TrippyLighting
Insert -> Insert Mesh
Solid -> Create -> Base Feature
Right -click on mesh and select "Convert" from menu.
Message 14 of 16
vinc.beaulieu
This is way more clean than the approach I was using. Thank you!
I found the two approach also described on this page:
https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/sfdcarticles/sfdcarticles/How-t...
Message 15 of 16
a.monopoliQCTV2
Ey, There is a litle hack for this! basically there is no function for mirroring a mesh itself, but you can mirror components. So if you create a component from the mesh you want to mirror then you can mirror the component hence you will have a mirrored mesh.
Regards !
Message 16 of 16
hoffmann8VMZH
Observer
Observer
Wow!
I love you ❤️
Thanks!
