lines dont match the fill shape
harveypolglase
harveypolglase
hi, still earning and getting to grips , slowly, with fusion...
quick question, why are the lines 'off' the fill....
wersy
Maybe you better use loft.
Can you share the file?
harveypolglase
 This is the canvas, basically im trying to do a 0.4mm offset, inside and outside the black lines.. so i can extrude different parts for 3d printing... trying to make a stained glass effect
wersy
Convert with a free converter png to svg.
Import svg.
Then extrude as you like.
Redruth in South England?
wersy
@harveypolglase
Does the svg work for you?
If so, please be so kind and mark it as solved.
harveypolglase
sorry, havent tried as yet, been stuck in hospital 😞
I'll try as soon as i get home
wersy
Get well soon!
