Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Mate AXIS'S
3 REPLIES 3
LIBBIT_DESIGN
163 Views, 3 Replies
Mate AXIS'S
Hi, is there a way to mate 2 axis's? I have a helix conveyor with a taper roller and need to mate the center of the roller to the center line of the conveyor side roller cutouts. See attached screen shoot.
3 REPLIES 3
davebYYPCU
in reply to: LIBBIT_DESIGN
Joints will not work with Construction articles,
Replace the destination axis, with a sketch line.
Joint the midpoint of the Roller to the mid point of the new sketch line.
Pattern the initial Roller.
Might help…..
As long as the Axis are an integral part of each component, you can use the Align command to place one axis on the other.  Align results are only temporary and must be secured using other commands such as Pin.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
LIBBIT_DESIGN
in reply to: davebYYPCU
Hi DAve, that works great. Tks
Technology Administrators
