Hi, is there a way to mate 2 axis's? I have a helix conveyor with a taper roller and need to mate the center of the roller to the center line of the conveyor side roller cutouts. See attached screen shoot.
Solved by jhackney1972. Go to Solution.
Solved by davebYYPCU. Go to Solution.
Joints will not work with Construction articles,
Replace the destination axis, with a sketch line.
Joint the midpoint of the Roller to the mid point of the new sketch line.
Pattern the initial Roller.
Might help…..
As long as the Axis are an integral part of each component, you can use the Align command to place one axis on the other. Align results are only temporary and must be secured using other commands such as Pin.
John Hackney, Retired
