Mass not Accurate
Mass not Accurate
garryson09
Message 1 of 44
Mass not Accurate
garryson09
Guys, Why is my Mass on this component not accurate. My dimension length with that is around 200mm, and im using titanium as material, the mass should be in kilograms by now around 10kg or more. How to fix this to accurately correct the data?
Replies (43)
Message 41 of 44
garryson09
sir i cant concentric the two arcs. im stuck in here
Message 42 of 44
garryson09
is this correct sir
Message 43 of 44
TheCADWhisperer
The forum is not working correctly - making effective communication impossible - so I am going to go elsewhere where I can make more efficient use of my time.
Make the two points shown in attached image Coincident.
I attached partially finished part - see if you can reproduce the steps.
Message 44 of 44
garryson09
Thank you so much sir for the help!
