Mass not Accurate
Mass not Accurate
garryson09
Message 1 of 44
Mass not Accurate
garryson09
Guys, Why is my Mass on this component not accurate. My dimension length with that is around 200mm, and im using titanium as material, the mass should be in kilograms by now around 10kg or more. How to fix this to accurately correct the data?
Replies (43)
Message 2 of 44
rajeshpolamuri
Hi @garryson09
It might be the scaling ratio. It's seem to be smaller than the original. One's varify it. And adjest the scaling ratio.
Hi everyone, I am Rajesh. I am graduate of Mechanical Engineering in India. I am passionate on creative works like CAD, Art's, Edits, Designing, Etc..... I am also an Autodesk Student Ambassador. I was always shows my interests on the works. Which makes effective and updating every time, With the modern world.
Message 3 of 44
garryson09
How can i adjust the scaling ratio sir?
Message 4 of 44
g-andresen
hi,
Please share the file.
File > export > save as f3d locally  > attach it to the next post.
günther
Message 5 of 44
rajeshpolamuri
Go to > Modify > Scale
And adjest the scale as per requirement.
@garryson09
Message 6 of 44
garryson09
https://a360.co/37eYxjD
 Please refer to this sir. I cant share it locally because im education license. Thanks
Message 7 of 44
garryson09
got it sir. But ithink scaling is not the solution? because my dimension also changes. My dimension is quite already in standard. Im really confused why is it that my mass, density is not accurate compared to actual component
Message 8 of 44
g-andresen
How do you get to 10 kg?
For me the mass is plausible.
The specification 0.004 instead of 0.0045 is caused by the settings in your preferences and has no influence on the calculation of the mass.
Günther
Message 9 of 44
TheCADWhisperer
I see a lot of issues with your model.
Are you interested in learning how to model this assembly correctly?
Message 10 of 44
rajeshpolamuri
The mass of the Piston Rod will be in grams itself. as you are using Titanium it radiuses to 200g. ones take a look @garryson09
and you jest want to cobined both the small end and the connecting rod here.
Message 11 of 44
garryson09
Yes please, highly appreciated! Also, can you teach me how to properly simulate my component?
Message 12 of 44
garryson09
Yes sir. Will review it carefully.i think you are right
Message 13 of 44
garryson09
Let me study first my model. I remember i got to handle a con rods, and it weighs heavy. May its because the piston isnattached. But i think the mass is also correct. I will study first
Message 14 of 44
TheCADWhisperer
I must warn you that my help would require starting over, completely over, like learning to walk again.
In past years, only 2 or three people who have replied, Yes, have been willing to follow through with the effort.
(Actually I think it might have only been 1 person.)
Message 15 of 44
garryson09
yes its okay. Ill take my time. As long as my specification is met and thr features is still there
Message 16 of 44
TheCADWhisperer
@garryson09 wrote:
Ill take my time.
This can go very fast, or it can stretch out over weeks - you set the pace.
Start a new file.
Sketch the rectangle as shown and then add Midpoint constraint to the Origin.
Select the top and bottom horizontal lines and right click toggle them to Construction (this step isn't technically needed - but will make things just a bit easier down the road.
Sketch the two circles as shown - snapping to the midpoints of the horizontal construction lines.
What do you observe about the color of the geometry?  (Is it blue or is it black?)
Message 17 of 44
TheCADWhisperer
Finish Sketch1 and start a New Sketch.
P for Project and select the centerpoint of the smaller circle.
Select OK.
Add the two circles as shown.  What do you note about the color of the circles. (Are they blue or are they black?)
Message 18 of 44
TheCADWhisperer
Sketch another large circle (without dimensions) at each end.
Then Dimension, select a circle and then Right click and select Radius dimension.
Dimension as R35 at small end and R40 at large end.
What do you note about the color of the two new circles - before and after dimensioning?
Message 19 of 44
TheCADWhisperer
Hide the visibility of Sketch1.
Sketch a vertical construction line between the centerpoints of the circles.
Sketch a vertical object line to the left of the construction line.
Mirror the underconstrained blue vertical line to the right side of the construction line.
Add a 20mm dimension between the mirrored lines.
What do you observe about the color of the lines after dimensioning?
What do you observe about the color of the endpoints of the lines?
(As we continue - we will see that observation of changes in geometry are critically important.)
Message 20 of 44
garryson09
its blue because the geometry is well defined?
