Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Making a thread on a tapered extrusion?
2 REPLIES 2
404 Views, 2 Replies
Hi All.
I'm newish to Fusion, but i've ran into a problem.
I've created a taper and i wish to thread it.  Also a nut will screw up the taper to tighten the tube within the taper assembly.
A bit like a bowden tube clamp, but this is for liquid.
Can anyone please advise me how to carry this out.  I cannot see a thread option nor coil option on the taper.
Many thanks. f3d enclosed.
Regards
Mike
2 REPLIES 2
wmhazzard
The coil command does have a taper option. You should use that and sweep your thread profile using a path plus guide rail from the coil.
Use coil command for taper extrude
Technology Administrators
