Hi All.
I'm newish to Fusion, but i've ran into a problem.
I've created a taper and i wish to thread it. Also a nut will screw up the taper to tighten the tube within the taper assembly.
A bit like a bowden tube clamp, but this is for liquid.
Can anyone please advise me how to carry this out. I cannot see a thread option nor coil option on the taper.
Many thanks. f3d enclosed.
Regards
Mike
The coil command does have a taper option. You should use that and sweep your thread profile using a path plus guide rail from the coil.
