- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
This has been happening for quite awhile on my macbook pro 2015 with OS 10.12.3.
I'll be designing something then all of the sudden none of my mouse clicks register. If I wait some will register, say Im sketching a line, I'll be able to click a start point, but it seems to freeze and wont show the line or allow me to click an end point, if I ESC out of the line, I can navigate around the workspace normally, get in and out of sketches, or navigate to another workspace normally, but I cannot actually select a face on a model. If it does allow me to actually select something when this happens, if I try to extrude, it wont let me use the slider on the model at all, but I can enter an extrude distance in the extrude box and the extrude happens normally.
I use a wireless mouse with a usb dongle, but when this happens I also cannot click anything in the program with the trackpad. outside of fusion360 the mouse and trackpad work normally.
I've noticed this happens under 2 circumstances, the first and most frequent is when I tab to another window, when I tab back to fusion it happens almost 90% of the time. Closing a project and reopening it sometimes works, but mostly does not. If I close fusion360 all together and re open, as long as I dont tab out of the program it works for a time, but eventually will start acting up again.
I also use fusion360 on a windows machine, and have never had this issue. I've had quite a few fusion crashes on the mac and have sent many crash reports, most of which, this issue was involved.
