Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Low quality T spline model
3 REPLIES 3
aaronfinger
174 Views, 3 Replies
Hey everyone, I have a t spline mesh that I needs to have a smooth surface. When opened in Cura, the model is cleary doesn't have a smooth surface, see attached for details. How do I make smooth models using t splines in fusion?
3 REPLIES 3
g-andresen
in reply to: aaronfinger
change Refinemant to "Custom" and mofify surface deviation
günther
wersy
What you are showing is the print preview.
What you see is the seam of the layer change.
aaronfinger
in reply to: g-andresen
This worked, thank you very much.
Technology Administrators
