Loft tool not working properly
mwhines5
mwhines5
I am currently trying to make a boat hull for 3D printing. I have made the rough hull design but I am struggling to get the loft tool to work properly.
I am also trying to get the thickness of the walls to be 10mm, but I have no clue how I would get that done, so help on that front would also be great!
I have attached the file bellow.
Thanks for any help 🙂
@TheCADWhisperer
davebYYPCU
Not using Sketch 6 will avoid a crease, Split body for a flat deck line.
Small steps will build it up.
10mm is very thick for 3d print.
Might help....
mwhines5
Thanks mate!
This really helps 🙂
Beyondforce
Hey @mwhines5 ,
Check out this YouTube playlist it's a lot of info that I'm sure will help you with building a 3D boat in F360:
https://www.youtube.com/playlist?list=PLjGKAi--ZCobt6eBTiT9ahIawIK4WQjqh
Cheers.
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
