Setting View Cube default?
atdNMH7S
atdNMH7S
I'm trying to set the default for View Cube to match what's shown in the screen shot. I've tried going to Preferences and changing Default Modeling Orientation to Z Up, but the result isn't the same. Thanks in advance for any suggestions.
wmhazzard
How is your result not the same?
sanjana.shankar.goli
Autodesk Support
Autodesk Support
@atdNMH7S
Right click on home button near the View Cube and try this
Sanjana Goli
Software QA Engineer
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
atdNMH7S
Actually, after closing and reopening Fusion 360, the cube now displays as desired. Apparently it just needed a program restart?
atdNMH7S
Thanks. As noted in my other post, when I restarted Fusion 360 the cube appeared as I'd wanted it to. But good to know about these settings.
