Model a coil, shaped around a square or rectangle.....
sjnoble
sjnoble
Pretty sure I searched this both here and world wide web.  Seems that the "coil" feature added sorta recently is a really cool thing and it's handy, I like it.  I'm needing to model a coiling tube around a square profile and wow that's proving to be quite the chore.  1/2" OD pipe, approx 9" diameter square pattern.  I've attempted several drawings (some in 3d) hoping that the "Pipe" feature will follow the path after all my drawings.
Many times I've started with a bottom drawing, functional bend radius and then used a "plain at an angle" based on feature measurements from the Coil Feature.  Then attempt to copy a pattern, then try the Pipe Feature.  This work around is not working, at least for me.
Perhaps someone here has attempted this and has a smoother "path" 😃 forward.
Many thanks,
Scott
davebYYPCU
Smoother path?  Not sure what you mean,
No bend radius, or pitch mentioned,
This might get you started...
TrippyLighting
I answered that same question today in this thread.
