Message 1 of 49
Local Render and cloud render are different....
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Ok this drives me nuts, why does the local renders look different then the cloud renders?
You can see the white dashed lines at the bottom corners...then the white highlights on the floor around the feet......
This needs to be fixed, it shouldn't make any difference other then time to render between local and cloud rendering.
It appears that the local render uses a polygon lower resolution mesh then the cloud uses..........You can actually see faceting at the rounded edges on the local render but not on the cloud render.......
Local:
Cloud render:
Issue:
Phil Procario Jr.
Owner, Laser & CNC Creations![]()
