Joint oriantaion
Joint oriantaion
lama_aqel88
Joint oriantaion
lama_aqel88
hi againe ,
If i have a assempy contain if 3 bodies they joint to gother
I need they move sliding upside down and the top face join as a revolving with the part so it move revolving upside down when i move the part sliding ... All what i need is how to make the top face of the body stay to up and dont revolve with the sliding motion to down
Thats it
Regards
joel.palioca
Are you able to attach the file you are working with?
There are a couple different ways you can work with joints.  One thing you can investigate is the option to ground a component so that it won't move, as long as the rest of your bodies are assigned to seperate components you can continue to have the motion without it impacting the grounded component.
Cheers,
[Joel Palioca]
[Software QA Engineer]
Joel(dot)Palioca(at)autodesk(dot)com
Autodesk, Inc.
lama_aqel88
Hi thank you for your reply
Not that what i mean , for sure any motion examination should make one componant grounded to aee the motion .
Once i get access to pc i will attach the file .
I need to make base grounded with arm that move cellindee up side down with out rotation fusion cannt make it
