.stl file
.stl file
Message 1 of 8
.stl file
How can I get this stl file model  converted to a model that will accept sketches and extrusions?
Replies (7)
Message 2 of 8
TrippyLighting
The scan quality of his file appears to be such terrible quality that I am wondering what you intend on doing with this ?
What is you end goal ?
Message 3 of 8
The file is just to see what needs to be done get to a solid model.
Message 4 of 8
keqingsong
This video should help:
[video]
Keqing Song
Autodesk Fusion Community Manager
Portland, Oregon, USA
Become an Autodesk Fusion Insider
Message 5 of 8
thanks that is helpful.
Message 6 of 8
innovatenate
Autodesk Support
Autodesk Support
There's an awesome video by @MichaelAubry about using Mesh files, MeshMixer, and Fusion 360 to get solid bodies.
https://www.youtube.com/watch?v=yMaih-vPNr4
Without looking the attached 21 MB file, my guess is that mesh is too dense for conversion. You can use the reduce tools in MeshMixer, to lower the triangle count.
Another good tip is to use Autodesk Momento to convert your triangle Mesh into a Quad Mesh. This will make for a smoother conversion to T-Spline (Sculpt) Bodies > to BREP.
Check out the below Autodesk University class for some further info on this topic.
http://au.autodesk.com/au-online/classes-on-demand/class-catalog/2015/fusion-360/cp9883#chapter=0
Nathan Chandler
Principal Specialist
Message 7 of 8
TrippyLighting
I'd ad to @innovatenate and @keqingsong that you should search the forum and come here often.
The Forum is full of unusual solutions and that also particularly relates to "STL import". That serach term alone will provide you with hours ofeducational reading 😉
Message 8 of 8
There is also the possibility to convert the STL file into a STEP file using InStep. It's really easy and not too expensive.
