How to render a Cork Material?
barentroth
barentroth
What is the best way to render Cork in Fusion 360?
Is it listed among the rendering materials and I have just missed it?
or should I try and create it? is so what's the best way to do that?
I have 3D form that is to be made in Cork.
martha.deans
Hi barentroth,
You can edit appearances, and in Advanced Settings > Parameters, you can set the image file for that appearance. So I grabbed an image off Google of a piece of cork and loaded that in as the texture, and now my part that was once metal is made of cork!
This is does leave kind of a square looking pattern, but I also just pulled one off Google like a noob 🙂
Happy Answer Day!
Marti Deans
Product Manager, Fusion 360 Manufacturing
TrippyLighting
Another ages old tip to boost the looks of your renders and which is very easy to do it to "bevel your edges", meaning you should put a littel chamfer or radius on each edge, particularly the ones close to the camera.
Also, instead of using just an image, look for a texture that includes a bump, or normal map and use the bump/normal map in the settings called "Relieve pattern"
kidd_milan
I had the same question and appreciated the extra info from @TrippyLighting about bump/normal maps.  Here's a free cork material "seamless" image along with a bump and normal map that I found:
http://www.texturise.club/2013/08/seamless-cork-wood-maps.html
And here's a brief background on how these maps work; it clarified quite a bit for me:
https://www.pluralsight.com/blog/film-games/bump-normal-and-displacement-maps
Though it seemed that the grayscale image was for the "Roughness" setting and the purple/blue for "Relieve pattern."
Cheers!
Milan
