joint help
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm working on a steam engine model. There is a crank mounted eccentric (white), driving a rocker arm (black) back and forth. The rocker arm needs to connect to a slide valve (blue) such that it moves back and forth. I can make this work with contact sets, however this requires more computer than I have. Looking for an alternative using joints.
@jhackney1972, you solved a similar problem on another design using a dummy component, and I suspect something similar is in order.
