I would like to place the left hole in the attachment along a centerline on the front face of the rectangle. I could do this with a sketch, or I could add reference distances for the hole---but I would simply like to draw a centerline along the length of the face and place the hole along this line, much as I would using sketch points.
I note that the right hole produce a "dot" at the dead center of the rectangle while I was placing it--so I was able to set it there and then set the edge distance with a reference which is fine.
But for the left hole I do not get the "dot" for some reason.
I have played a bit with construction planes but I don't think this is the right way-
Is there a simple way to do this or should I just add a sketch?
Fritz
