Locating Placement of Holes on Bodies
fsonnichsen
fsonnichsen
I would like to place the left hole in the attachment along a centerline on the front face of the rectangle. I could do this with a sketch, or I could add reference distances for the hole---but I would simply like to draw a centerline along the length of the face and place the hole along this line, much as I would using sketch points.
    I note that the right hole produce a "dot" at the dead center of the rectangle while I was placing it--so I was able to set it there and then set the edge distance with a reference which is fine.
  But for the left hole I do not get the "dot" for some reason.
I have played a bit with construction planes but I don't think this is the right way-
Is there a simple way to do this or should I just add a sketch?
Fritz
TheCADWhisperer
We have a winning technique...
When you finish the part - attach it here and I will show an easier way.
jeff_strater
Agreed.  Sketch is the way to go.  You said "but I would simply like to draw a centerline along the length of the face and place the hole along this line, much as I would using sketch points.". This is exactly what the sketch environment is for.  Is there a reason why you are hesitant to use a sketch?  Just curious.
Jeff Strater
Engineering Director
g-andresen
This is how I would do it.
günther
fsonnichsen
Thanks for the notes. I attached a version of the final part that would work. It uses sketches.
   To answer Jeff's question-my interest here was largely academic-  Not necessarily avoiding sketches--it is how I do most of my drafting. But for really simply objects like that attached I thought it would be quick. In fact a lot of times I would like to position a hole without resorting to a complete sketch. The two "reference select" options on the hole object work but sometimes you would just like a hole to track a centerline if the overall object breadth changes.  In general placing a "dot" on a center (similar to what the hole command SOMETIMES does) and having some centerline commands when working outside of sketch would be useful.
cheers
fritz
Thanks for the feedback
Fritz
TheCADWhisperer
Attached is my alternate technique.
I generally avoid extra trimming and duplicated dimensions (See Sketch1).
I can't help but wonder if you don't want clearance holes on one side and threaded holes on the other side?
fsonnichsen
Thanks for your reply. I agree on your simpler design-Part of my problem is that I often "think as a go" and when I am done realize I could have done something simpler---with experience of course, the intermediate solutions converge on the final ones.
  Re. the fasteners-This part will be in plastic and I will use wing nuts on one side (it clamps to a mic stand) --Not sure threaded plastic will hold up to some of the strength of my colleagues.
cheers
fritz
