Joint conflict - tutorial file
terryB2PX7
terryB2PX7
Following the tutorial on joints in Leson 5 of http://f360ap.autodesk.com/courses/mechanical-assemblies-fundamentals/lessons/lesson-5-assemblies-an....
Connecting crank arm to gear results in error:
Warning: Rev77
Compute Failed
Some positions cannot be resolved due to joint conflicts
Since this is a tutorial file, I am surprised to see an error.
Any suggestions?
davebYYPCU
Double check your selections, have you copied the tutorial?
Sounds like the crankrod is being asked to change height,
The tutorial selection under the crankrod, was the bottom of the orange bush,
No,  you should not be getting an error if all the file is the same as the tutorial.
If you export the file, and attach it,  we can answer with your data.
Might help...
terryB2PX7
Attached is my version of the tutorial file with joint issue.
terryB2PX7
Found that gear pin was positioned 0.2mm high
davebYYPCU
and all is good, or still getting the error?
