Message 1 of 9
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi folks, I need a bit of help with a joint. I want to join 30+ hoops to a spine, equally spaced apart. I have each of the components designed already.
The hoop has a channel in it that's 0.4" tall with a 10" radius - the exact same as the outer dimensions of the spine. I tried a cylindrical joint with the cylindrical faces (outer spine face and inner hoop channel face) and a planar joint with the top planar face (top of spine and bottom of hoop channel). But it's not joining the way you would expect.
What's the best way to join these? What's the best way to space them equal distance apart?
See attached for file.
