Join and lock align
Join and lock align
rticr
Message 1 of 9
Join and lock align
rticr
Hi Guys; hope you can help!
I have a project where the dimensions will change, but the design will remain the same.  As such I'm trying to keep everything so that I can easily change my user parameters to quickly change details in the design.  I have run into this issue
I have 3 components (see picture) and want to Join Component 3 to the other 2 and align it to the bottom.  I know how to do this fairly easily; I make a Join so Component 2 aligns at the bottom of Component 3 and then using "Offset Y" click the bottom face of Component 1 and Job Done
However, if I change the height of Component 1, then  it makes no effect on Component 3
What is the best practice in this scenario?
Replies (8)
Message 2 of 9
TrippyLighting
Can you share your model? (export as a .f3d file and attach to your next post)
Message 3 of 9
rticr
Project attched
Message 4 of 9
wersy
How if you create a base dummy?
Message 5 of 9
g-andresen
The concept by @wersy  also works without dummy
Screencast
günther
Message 6 of 9
laughingcreek
It's easier to do designs like this that are robustly parametric using a top down, skeleton sketch approach.  I would suggest retooling your general approach to design. see attached.-
Message 7 of 9
rticr
Brilliant - thanks, guys!
Message 8 of 9
TrippyLighting
Please mark one or more of the answers as a solution.
Message 9 of 9
rticr
Thanks - will look at this, and agree it looks like the best approach. Learned a couple of new things nonetheless 🙂
