Invisible objects
Invisible objects
不适用
3,424 次查看
20 条回复
1 条消息(共 21 条)
Invisible objects
不适用
hi,
I wanted to start my first model with fusion 360.
The problem is that the 3D objects are not visible, unless I double click on it (the 2D objects in the sketches are visible).
I have the same problem if I import a model file created with another program (solidworks).
Can someone help me?
0 个赞
已接受的解答 (1)
3,425 次查看
20 条回复
回复 (20)
2 条消息(共 21 条)
HughesTooling
Can you attach some screen shots please. And export a design from the file menu and save as f3d and attach.
Thanks Mark
Mark Hughes
Owner, Hughes Tooling
0 个赞
3 条消息(共 21 条)
Oceanconcepts
When you say not visible, do you mean completely missing, or showing as a wireframe? What are you double clicking on- in the drawing or in the browser? If you look for the 3D object in the browser, can you see it listed, and is the little light bulb visibility icon turned on?
- Ron
Mostly Mac- currently M1 MacBook Pro
0 个赞
4 条消息(共 21 条)
HughesTooling
As Ron pointed out are you picking a component but the body bulb is off like this.
Mark
Mark Hughes
0 个赞
5 条消息(共 21 条)
HughesTooling
One more question has Fusion worked for you at all, you say even an imported part doesn't display which sounds odd. One thing to try click the question mark, top right, select Graphics Diagnostics and on the next dialog select Limit all effects and see if that helps. Also can you get a screen grab of the dialog.
Mark
Mark Hughes
0 个赞
6 条消息(共 21 条)
Oceanconcepts
I have experienced in the past a similar odd issue when my default material in my materials library disappeared, as a result of a crash reassigning materials to a “favorites library” that didn’t exist. That resulted in all new and imported 3D objects being rendered with an invisible material. If none of the above suggestions apply, you might try dragging another material to the object (right mouse to get the marking menu, select Appearance) and see if visibility changes. If it does, check your Materials settings under preferences and see that they are set to "Fusion 360" materials library.
- Ron
0 个赞
7 条消息(共 21 条)
不适用
I post some screen shots.
In picture 1 you can see what I see when i open Fusion 360. In picture 2 you can see what I see when i try to create a cilinder (with comanand: "create"-->"cylinder"). In picture 3 you can see the cylinder just because i double clicked on the area where I ASSUME the cilinder is. If I don't double click, the cylinder is not visible.
0 个赞
8 条消息(共 21 条)
不适用
this is the graphics diagnostics:
0 个赞
9 条消息(共 21 条)
HughesTooling
You don't have a lot of memory on that card, try ticking the Limit all effect box.
Also noticed there a error message reminder at the top of your screen, what does it say when you click on it
Mark
Mark Hughes
0 个赞
10 条消息(共 21 条)
不适用
the error is due to an update ("the product version database is currently locked due to an update or install already in progress")
0 个赞
11 条消息(共 21 条)
HughesTooling
Has Fusion worked for you on this computer and is this display problem something new. The error seems odd as the last update was about a month ago, so I'm wondering if your last update went wrong.
Mark
Mark Hughes
0 个赞
12 条消息(共 21 条)
Oceanconcepts
If you go to the Fusion 360-- Preferences and select Materials, what do you see? Can you post a screen shot? This looks just like what I experienced with an invisible default material. That problem was associated with a crash or failed update.
- Ron
0 个赞
13 条消息(共 21 条)
不适用
I've downloaded and installed Fusion a couple of days ago...
In the screen shot below I selected "steel" as material. Nothing changed.
0 个赞
14 条消息(共 21 条)
HughesTooling
You are using Physical Material not appearance. Just drag and drop one of the materials onto the body. Also Steel might be the default so if there's a problem with that material you need to try some others.
Mark
Mark Hughes
0 个赞
15 条消息(共 21 条)
chengyun.yang
From your graphics diagnostic dialog, this could be caused by that your graphics card driver is not installed properly. Can you please go to your GPU vendor website, download the latest GPU driver there and try again?
Chengyun
Fusion Development Team
0 个赞
16 条消息(共 21 条)
不适用
Tried even with gold, no different results.
later I'll try with the GPU....
0 个赞
17 条消息(共 21 条)
Oceanconcepts
Actually what I was asking about were the materials settings in Preferences, and specifically to check and see what materials library is active. But the fact that you don’t see a change when you use another appearance material indicates that you don’t have the same issue I did.  I would follow up with Chengyun’s suggestion re. graphics card drivers.
Another possibility is to try removing and re-installing Fusion. http://fusion360.autodesk.com/learning/learning.html?caaskey=caas/sfdcarticles/sfdcarticles/How-to-d...
- Ron
0 个赞
18 条消息(共 21 条)
不适用
hi,
my GPU vendor has no drivers for my PC (maybe because my GPU is older than the other components of the PC).
So, if you don't have any other ideas of how to solve the problem, I think I'll buy another GPU  and then we'll se if something changes...
0 个赞
19 条消息(共 21 条)
不适用
hi,
before I buy a new GPU, I post a screen shot of the one have. Isn't that good for fusion?
0 个赞
20 条消息(共 21 条)
HughesTooling
已接受的解答
The minimum specification for Fusion is 512MB, I don't know if the shared memory is the same as having 512MB of dedicated. System Requirements.
Have you tried ticking the limit all effects check box? Also if the newest driver you can get is 2009 then the design of your card must be at least 6 - 8 years old so it might not be up to the job.
Mark.
Mark Hughes
0 个赞
