Interface / move button ?
Can i move Component button higher in the browser tree?
( With Ctrl i see plus sign - what is it?)
Body button i can move
Dodaj do listy blokowanych banerów
HughesTooling
The order in the browser is the same order the components are created in the timeline. You might be able to drag the component along the timeline. Personally I like to keep my components and the features that create them together in the timeline so I wouldn't just drag the component along the timeline without its features but this might stop you moving the component along the timeline if it has dependencies to other components.
Mark
Mark Hughes
Owner, Hughes Tooling
hmmm...
thx
but sometimes i need move it
well...
innovatenate
Autodesk Support
Autodesk Support
I wanted to note if you don't care about your parametric timeline, you could convert the design to a direct modeling environment. This should allow you to drag components around in the browser more freely.
I hope that helps!
Nathan Chandler
Principal Specialist
i will try
