Insert Fastener Flip Issues
johnhow62Autodesk
Observer Observer
Message 1 of 10
johnhow62Autodesk
Observer
Observer
I am trying to use the insert fastener tool, but I can't get the fastener to face the right direction. I have tried multiple holes and faces, and it seems only to let me place the fasteners facing outward (See Screenshot).
Replies (9)
Message 2 of 10
akash.nawghare
Hi ,
You can use Move command to align the fastener.
Message 3 of 10
laughingcreek
fine tune the placement by editing the joint created when you insert it.
Message 4 of 10
mustafamteck
Hi there,
The same question can someone please tell me, how can I align fasteners correctly using the insert fastener tool when they always face outward, no matter the hole or face I select?
Message 5 of 10
laughingcreek
set the secondary position.
Message 6 of 10
johnhow62Autodesk
Observer
Observer
Thanks for the response! I was looking for a way to do it using the Insert Fastener tool so that I didn't have to move each bolt because there were so many.
Message 7 of 10
johnhow62Autodesk
Observer
Observer
I was trying to do it inside of the tool so that I didn't have to go back in and move each one, but thank you.
Message 8 of 10
johnhow62Autodesk
Observer
Observer
I was attempting to do this, but I could only select the inner face. It might be an issue with the "Structural Member" add-in I used to create the member.
Message 9 of 10
laughingcreek
the secondary face needs to be planer.  I can't tell from the pics if it is or isn't, but I'm guessing not
you could attach your .f3d if yo want us to try.
Message 10 of 10
Roman_Vesely
Hi Mustafamteck,
 I guess that you have design with SURFACES and Fasteners are inserted on one side only, right ? In this case, you can insert Fasteners on "SKETCH POINT(s)" and there is an extra option "Flip" which you can use it directly from the Insert Fastener command. For more information see video :
Best Regards
 Roman
Roman Vesely
Inventor - Principal QA Engineer
