I am learning to use the drawings workspace of Fusion 360 and am trying to find a solution for showing each part on a separate sheet, including the quantity required.
Screenshot of a simple example attached - I want the drawing to show a single item as demonstrated, but want the quantity in the parts table to be the total in the model (24 in this case).
Can I have the total quantity in the parts table but only draw a single occurrence?
thanks
*edit* I should note that it is possible to show one part only but have the total quantity in the parts table by having all occurences unsupressed but hidden (see second screenshot), but this means the part name and number in the drawing title now takes on the name and number of the parent component... In this example, I'm trying to have a sheet for the part "Shelf" with the name/part number in the title block and total quantity in the table. I would then duplicate this sheet for every part type.
Hi @Luke_AU
I'd love to talk to you about your workflow. If you're up for it, here is a link to my calendar, please book a 30-minute session with me, and we can chat on Zoom (Note that times are in 24:00 format so 03:00 is 3am, 15:00 is 3pm). Or if a good old-fashioned email is more your style, feel free to ping me Clint. Brown {a} Autodesk.com
Hi Mustafa
Thanks, I tested this manual titleblock and it does give the ability to achieve what I'm after - the part name & number then become "fixed" on that drawing, regardless of objects shown in the tree.
Only downside is the title block needs to be reset if duplicating that sheet or changing what is shown on it.
