Extrusion konisch - Extrusion conical
heinzgitz66
heinzgitz66
Hallo ins Fusion 360
Ich möchte gerne eine Extension konisch durch gehend machen als Anfänger, aber irgendwie geht es einfach nicht einer hat Sicher eine Idee und kann Mir weiter Helfen.
Hab dazu auch dazu Bildschirmfotos gemacht und die Fusion 360 Datei gleich mit gesendet.
Gruss
heinzgitz
 [translated with Google]
Hello to Fusion 360
I would like to make a conical extension as a beginner, but somehow it just doesn't work. I'm sure someone has an idea and can help me.
I also took screenshots and sent the Fusion 360 file along with it.
Greeting
heinzgitz
jhackney1972
I think you want to create a conical extension on the end of your body.  You specified the base diameter but you did not mention the angle or the height.  Your original body was created using cached geometry as your sketch is missing.  Probably the reason you could not create the base of the cone is because the surface you want it on is not flat.  You can edit the cone using the last Extrusion in the timeline.  Model attached.
John Hackney, Retired
heinzgitz66
Hallo jhackney1972
Dachte Du antwortest Mir in Deutsch zurück.
Werde mal versuchen deine Typs umzusetzen, aber die unter Seite ist doch flach, dann sollte doch mit der *Extrusion* wenigstens von dieser Seite aus gehen, oder liege ich da völlig falsch mit meiner Annahme.
Gruss
heinzgitz
Thought you would answer me back in German.
I'll try to implement your type, but the bottom side is flat, then the *extrusion* should at least work from this side, or am I completely wrong in my assumption.
Greeting
heinzgitz
jhackney1972
You have posted to the English Fusion 360 Support Forum so I am using my native language.  The end of your model where I assume you want the conical extrusion is NOT flat.  I used a surface feature to create a flat surface and extruded both ways, one way just enough to bridge the gap in the curved surface so I could combine the new body with the original.  If you think it is flat, try to create a sketch on it, you cannot.
CGBenner
@heinzgitz66
Good day!
You are always welcome to post here in the English language Fusion forum, but if you are more comfortable in your native language, we do have a German language Fusion forum that you might enjoy.
Thank you, and good luck!
Guten Tag!
Sie sind jederzeit willkommen, hier im englischsprachigen Fusion-Forum Beiträge zu posten. Wenn Sie sich jedoch in Ihrer Muttersprache besser auskennen, haben wir auch ein deutschsprachiges Fusion-Forum, das Ihnen gefallen könnte.
Danke und viel Glück!
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
heinzgitz66
Guten Abend CGBenner
Ich bin halt immer noch Fusion 360 Anfänger, manch mal triftet ich halt in Englische Sprachige Forum ab als in Deutsch Sprachige Forum, die Fusion 360 Suche macht es einen halt auch nicht immer einfach ob wohl man Deutsch eingestellt hat.
Entschuldung für die Annehmlichkeiten.
Gruss
heinzgitz
