The results look correct to me for your setup. I do not think your selection of the Constraints are correct. Two of the legs of this table should be free to slide on the floor so Fixed should be replaced with Frictionless. The maximum displacement for your configuration is 11.75mm, with Frictionless constraints it is 12.36mm. As you would expect, since the table leg, on one side, can slide on the floor, due to the flexing of the legs, you get a different maximum displacement. My model is attached.
John Hackney, Retired
