Inaccurate FEA Results
ReachShaun
Message 1 of 8
ReachShaun
I'm not sure what's going on here. These FEA results don't seem to be accurate. Can someone take a look and tell me where I went wrong?
Replies (7)
Message 2 of 8
jhackney1972
The results look correct to me for your setup.  I do not think your selection of the Constraints are correct.  Two of the legs of this table should be free to slide on the floor so Fixed should be replaced with Frictionless.  The maximum displacement for your configuration is 11.75mm, with Frictionless constraints it is 12.36mm.  As you would expect, since the table leg, on one side, can slide on the floor, due to the flexing of the legs, you get a different maximum displacement.  My model is attached.
John Hackney, Retired
Message 3 of 8
ReachShaun
Update: After changing the fixed constraints to frictionless constraints, I am now getting failed results during the solving process.
Message 4 of 8
ReachShaun
I see you made only the back legs frictionless, which passed the test. However, wouldn't both legs slide on the floor when a load is applied?
Message 5 of 8
jhackney1972
Please note that I only changed "two" fixed constraints into frictionless constraints.  You can take a look at my supplied model.  You have to have two legs, on one side, with fixed constraints to keep the table in position.  I would expect a failed solution if you change all the leg fixed constraints to frictionless.
Message 6 of 8
jhackney1972
Sorry, your post came in as I was typing.  Well in real life all legs will try and spread but in this simulation Fusion 360 cannot compute that condition.  If two legs slide on the floor, you will get the same result.  Think about it, if you put the table legs, on one side against the wall or some stop, the other two legs would just move as required.
Message 7 of 8
ReachShaun
Thank you for your help! I will mark your advice as the solution.
Message 8 of 8
TheCADWhisperer
@ReachShaun wrote:
...wouldn't both legs slide on the floor when a load is applied?
You are doing Static Analysis - not Motion Analysis.
