In the drawing environment, can I have an exploded view created from the animation environment no effect the title block and mass?
ParametricScenicXYZ
Message 1 of 8
ParametricScenicXYZ
Hey,
When I do a drawing and I add in a exploded view to give context for another component thats on the sheet. The title block updates to the top level component and mass. I want the title block to ignore the view added from the animation environment.
At the moment the only way I can think of doing it is to add the animated view as a jpeg. But of course that wont update automatically.
I'm really trying to avoid exporting my 3D models to AutoCAD
Replies (7)
Message 2 of 8
HughesTooling
Edit. Sorry should have read to the end of your post a bit more carefully!
Mark Hughes
Owner, Hughes Tooling
Message 3 of 8
HughesTooling
OK, think I've done what you describe but I don't see the mass in the title block change after adding the story board as a base view. Have I done something different to you?
Edit.
I see now if you only have one component in the original base view but the whole assembly in the exploded view you get the mass for the assembly! You even get the total mass if you hide parts in the exploded view. @ClintBrown3D Any ideas about this?
Mark Hughes
Message 4 of 8
ParametricScenicXYZ
Hi Mark, you've captured my predicament perfectly! Thank you for investigating.
Message 5 of 8
ClintBrown3D
Hi @ParametricScenicXYZ
I’m sorry that you are having trouble. I've asked the team to take a closer look at this issue for you. I can also reproduce the issue here. One of the team members will let you know what we find.
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
Message 6 of 8
ParametricScenicXYZ
Thank you both for looking into this!
Message 7 of 8
Ruby4_test
Hello @ParametricScenicXYZ
I can see this behaviour at my end as well, when we add a new view chain or new storyboard we get the total mass of the assembly and this seems a known behaviour. We have a task to include a source to the title block to make this as the user wants. For now can you please try the below workaround ? Let me know if this works for you.
  1. Add a new/duplicate title block for the sheet you want to have this material and mass information.
  2. Do not add attributes of mass and material in this Title block.
  3. In this sheet Add Text and Add Properties for Material and Mass and place in Title block as shown in image.
  4. Make sure when adding material and mass properties you select the proper source.
  5. Now when you add other views this material and mass will not change as this is reference the source you selected.
Thanks!
Mohammed Adam Ali
Sr. SW Engineer in Test
Fusion 360
Autodesk, Inc.
36/3-B, Business Plaza, Mundhwa Rd, Koregaon Park Annexe,
Ghorpadi, Pune, Maharashtra 411001
www.autodesk.com
Message 8 of 8
ParametricScenicXYZ
Hey Mohammed,
Thanks for coming up with this work around and for your clear instruction. I tried it out and it worked great thank you.
Something else for my tool kit!
