Text TAG
Text TAG
MichaelT_123
Advisor Advisor
Message 1 of 1
Text TAG
MichaelT_123
Hi Fellows,
… as I promised in:
https://forums.autodesk.com/t5/fusion-design-validate-document/text-bounding-box-and-parameterizatio...
Here is the one possible, not necessarily elegant, but potentially workable method of creating a framed text TAG (a label).
The attached file shows the main tricks, which I hope should be obvious to most. The following points should help to clarify the design intent even further:
  • There are a couple of user parameters driving the design
  • Dimensions are based on a font height (as referred to in the text dialog box)
  • Alongside various factors (descriptions in the respective UParams comments)
  • Font factors should be 'customized' based on the selected font
  • The design flow assumes that the font is of a mono-spaced family.
  • If not, you must rely on your 'good luck.'
  • The actual text can not be parametrized, so it must be entered manually
  • Consequently, counting the text length is also required (n_t param)
  • It is advisable to convert the TAG to direct modelling form before including it in the destined design.
  • As this would avoid unnecessary clattering of the latter.
  • The solution is about a fast TAG creation rather than a fully parametric workflow.
  • The method can be 'customized' as per requirements.
  • Even a multiline TAG option could be easily implemented.
As the epilogue (or one would hope prologue),… a couple of additional points:
  • The above method can be API scripted, presenting to the user a 'fool-proof' solution
  • I even committed one for the previous incarnation of sketchTextObject
  • But because this particular area is in the 'panta rhei'  state, it would be a lavish effort
  • The current text graphic procedure already has necessary data, which, when exposed, would give essential handles to deal with text (e.g. precise outline bbox, indentations)
  • It is perhaps a couple of lines of code
  • Currently, the 'string' data type is not permitted as a user parameter.
  • Upgrade in this area, …. and parametric text can become a reality in the basic design flow, … without external scripts.
  • Thus, … bang on F360 doors!
The attached file can be used in any legal activity you can fathom. Play with it as you wish … but responsibility is yours!
TextTAG.f3d                 F3D              (0.2MB)          https://a360.co/49bkq0w
Regards
MichaelT
MichaelT
Replies (0)
