Imported reference canvases are scaled incorrectly
simon.dyer
Message 1 of 8
simon.dyer
Fusion 2606.1.36 x86_64
Active Plan: Subscription
Windows 11 Home 25H2 (26200.8037)
See the image below, displayed bedsides the 1:1 import in fusion.  Standard JPG.
I've never seen this problem prior to latest update.
Replies (7)
Message 2 of 8
Drewpan
While I am not sure specifically what the problem here is, I am guessing that the image has
been distorted by fusion when you imported it from those pics.
I cannot tell you why fusion does this but as I frequently import a canvas when I am working.
I can say that you should never rely on the canvas scaling exactly when you import it. ALWAYS
use the Calibrate function after you have imported a canvas and when you get that correct you
then should position your Origin where you need it.
The good news here is that you have a handy reference tool to calibrate from so it should be
fairly exact. I find the most frustrating thing is it will not remember an Origin when you do
the calibration scales.
Cheers
Andrew
Message 3 of 8
TheCADWhisperer
@simon.dyer
If you Attach your original image file here - I will demonstrate how to fix the issue.
Message 4 of 8
simon.dyer
Hi Andrew, yes I always calibrate but in this case it is not correctly importing the aspect ratio
Message 5 of 8
simon.dyer
Here is the original photo - you can see the aspect ratio looks correct here also, so I do wonder why Fusion gets it wrong
Message 6 of 8
g-andresen
1. Open the file in any app and save it without editing it.
2. Import it into Fusion.
Günther
Message 7 of 8
simon.dyer
Thanks - that fixed it - although its weird because i changed thew photo by cropping it on the iphone after I took the photo there
Message 8 of 8
g-andresen
Fusion sometimes misinterprets the metadata of iPhone images.
As far as I know, this “strange” metadata is generated during the conversion from the original iPhone HEIC format to JPG format.
If you open the image in an app and save it without editing it, the metadata becomes “readable” for Fusion.
günther
