While I am not sure specifically what the problem here is, I am guessing that the image has
been distorted by fusion when you imported it from those pics.
I cannot tell you why fusion does this but as I frequently import a canvas when I am working.
I can say that you should never rely on the canvas scaling exactly when you import it. ALWAYS
use the Calibrate function after you have imported a canvas and when you get that correct you
then should position your Origin where you need it.
The good news here is that you have a handy reference tool to calibrate from so it should be
fairly exact. I find the most frustrating thing is it will not remember an Origin when you do
the calibration scales.
Cheers
Andrew
