Help with Fusion "Create Component"
overallmutes
Message 1 of 8
overallmutes
Used to have the option to create a "component" with in the file I was working on. That no longer appears under that in this latest version of Fusion360. It's either been renamed or removed as an option. I also HATE everytime I create a new design I get this stupid wizard which I don't understand what any of the options are and just want the user friendlyness of the earlier versions.  PLEASE HELP
@overallmutes
Your post title was modified to add the product name and for clarity of the issue and moved to the Fusion Design & Validate forum to increase findability by @CGBenner  - Original: HELP
Replies (7)
Message 2 of 8
g-andresen
For a better understanding, you should familiarize yourself with the new principle of intent driven design.
In this context, the “hybrid” variant is your friend, which also corresponds to the previous approach.
günther
Message 3 of 8
TheCADWhisperer
Message 4 of 8
rosie_lucas1
Hello @overallmutes,
Just checking in—did the responses shared by @g-andresen and @TheCADWhisperer help clarify your question?
If so, please consider clicking the "Accept Solution" button on the post(s) that solved your problem. Doing so helps others in the community easily find useful answers.
If your question still needs more attention, feel free to reply here with an update. This way, other members can jump in with further suggestions or guidance to help you move forward.
All the best,
Rosie | Community Manager
Message 5 of 8
shean5911x
That I believe will require repeating with each model. If you want to boot in the Hybrid mode goto top right tool bar, left click initials>Preferences>General>Default Design Type - select Hybrid click OK
Message 6 of 8
harald.sattmann
The problem is that in the free version it is not possible to create a component from scratch. I need to build a body to convert it to a component what changes design flow.
As far I used to create a component and worked on this until I need a new component. Than I created one. Now this is not possible anymore.
So my question: is it possible to create a component and start on this in the hybrid design work flow?
Thanks to all.
Message 7 of 8
jhackney1972
As you can see, from the attached screen capture, you can create a New Component when in Hybrid Mode with a Fusion Personal License.
John Hackney, Retired
Message 8 of 8
harald.sattmann
Thanks. I got it.
Harald
