Import STL, bodies are importing too smooth
charleslhaley
charleslhaley
I'm trying to import an STL from Thingiverse so I can make some adjustments to the screw sizes.  When I import it, the edges that that should be sharp are coming in smoothed, I've done this before many months ago and the meshes generally come in pretty good and allow me to make adjustments.  Is this just a setting issue on my part?
Note the 3 screw holes in this model:
Thank you
Charles
jeff_strater
I suspect that you just need to change how the mesh is rendered, using this preference setting, to "Flat Shaded":
Jeff Strater
Engineering Director
charleslhaley
That was the issue, thanks for the help.
Have a great day
Charles
