Import 3d path from another program
johnaboiles
johnaboiles
I'm trying to import 3d contours generated from some software I'm writing and generating a 3d model from it. Is there a file format that can be used to import 3d paths?
I've tried importing an .obj file that just contains edges but nothing shows up. I suppose I could make some fake faces along the edge and just delete them, but it doesn't seem very streamlined.
If this is possible with a simple file format, I wonder if there's a way I could write a plugin to import a 3d path. Any guidance would be super helpful!
g-andresen
First you should have a look at the import formats for each license type and then clarify which one is suitable.
günther
johnaboiles
This is the link you're referring to right? https://www.autodesk.com/products/fusion-360/blog/data-exchange-in-fusion-360-part-1/
I've looked through those, cutting out the proprietary Autodesk/Solidworks/etc ones I won't be able to add to my program I see
  • DXF Files (*.dxf)
  • FBX (*.fbx)
  • IGES (*ige, *iges, *igs)
  • NX (*prt)
  • OBJ (*.obj)
  • SAT/SMT Files (*.sab, *.sat, *.smb, *.smt)
  • STEP Files (*.ste, *.step, *.step STL Files (*.stl)
I tried an OBJ file with a line but it wouldn't import the lines -- just the faces. I could potentially brute force and try every single one, but was hoping someone would have some experience.
Edit: I started going down the list and I think I'll be able to get DXF to work in 3d, though it's a really hard format to read. At least it's plain text though!
g-andresen
this one too > Export Types
günther
HughesTooling
Dwg and DXF will import 3d curves but you will need to use the online translator not Insert DXF for DXF. If you have a commercial licence you need to use Upload in the data panel with DXF files, if you use Open the local translator is used and last time I tried 3d curves where ignored. Not sure if you can upload DXF files through the data panel with a personal license.
Mark
Mark Hughes
Owner, Hughes Tooling
