Idea: define a chamfer by constant length
andreaHFZCQ
andreaHFZCQ
Hi all,
Just realised a function is missing that I wish I could have: a native Chord Length or Constant Width option for chamfers. It exists for fillets, but not for chamfers.
Apologies if this might not be the right place to post about a missing function.
johnsonshiue
Hi! Before the enhancement becomes available, you could try this workaround and see if it helps. For the edges you would like to create the constant length chamfer, you may create a chord-length fillet. Go to Surface tab and delete the fillet faces. After that, create Loft surfaces to fill the gaps. Lastly, stitch the surfaces back to a solid body.
Many thanks!
Let us know how we did on Trustpilot.
Software Test Engineer
andreaHFZCQ
Great idea! Thank you Johnson
