I want to dublicate my sketch onto every side of the pyramid
6 REPLIES 6
480 Views, 6 Replies
https://a360.co/2Jyjpqv
Here it is. One one face I already made a pattern. I want to replicate it onto every side. I already tried two things:
  • Mirroring doesn't work and just gives me an error message.
  • Copy pasting the sketch places it right next to the faces, and it can't be moved.
How can I achieve this? Any ideas?
6 REPLIES 6
etfrench
It would be better to pattern the features instead of the sketch.  A circular pattern will do the trick. If you insist on using sketches, put the sketch in a component, then pattern it.
ETFrench
in reply to: etfrench
Just tried that, I'm getting an error again
etfrench
Your sketch and subsequent extrusions are very messy and are preventing the pattern.  I'll post a workaround after dinner.
ETFrench
etfrench
Start by reviewing Rule #1.
My first recommendation would be to start fresh and redo Sketch5.  I started to clean up Sketch5, but soon realized there were too many overlapping lines and my beard would be solid white before I finishedSmiley Happy
Since I was too lazy to fix the sketch, I used the current 3d body to recreate it.
You'll note when I created the bodies, I did it in three operations.  The reason for this, is Fusion 360 has trouble when multiple faces are connected along a common border.  The upper slot that goes nearly to the edge is also a problem. You should have either made the slot shorter or longer,so it didn't touch the edge.
ETFrench
etfrench
File is attached.
ETFrench
Thanks!
