Editing angles between lines
Message 1 of 8
I was just practicing fusion 360 with this tutorial video on YouTube, but I got stuck at 3:12~3:42 where the person changes the angle between two intersecting lines from 110.8 degrees to 248.5 degrees. I just don't understand how changing the angle didn't affect the initial angle. When I changed the angles, I got weird results. Does anyone know what really happened between 3:12~3:42? I've attached screenshots of my result and the tutorial video's result.
Video link: https://www.youtube.com/watch?v=Ooou9ZmEWPc
Replies (7)
Message 2 of 8
michael55SE4
I didn't see anything unusual in the time frame you mention.  If you edit an angle between two lines, which line moves depends on which one is constrained.
Message 3 of 8
lichtzeichenanlage
Can you create a screencast and / or share your project. Unless things are going strange after you've changed something it's hard to work with images. My guess: Constrains are missing.
Message 4 of 8
Please take a look. Here is the project. Thank you.
Message 5 of 8
Do you then know the constraints that I need to apply to achieve the same effect as the video's?
Message 6 of 8
Did the project I shared with you give you any clues?
Message 7 of 8
lichtzeichenanlage
Sry - I can't help.
Message 8 of 8
HughesTooling
I think the youtube video shows a bug, I've reported it a long time ago not sure if it's still a problem.
This screencast shows the same bug at around 15s.
Mark
Mark Hughes
Owner, Hughes Tooling
