How would I make a t-spline/form to match this design?
hieiswordflame
Message 1 of 14
hieiswordflame
I am reworking my model of the Sand Worm mural from DUNE, and I want to make it less of an extrusion and more of a malleable form that I can sculpt into shape. I have the outline of the form I want, and as you can see, there are certain breaks in it because of overlapping areas.
I have tried:
-Extruding and then converting to t-spline
-Sweeping/Lofting
I'm so confused on how to move forward. I assumed t-spline would be best because I could then pull out the ringed areas after getting the Sand Worm body right, but how the heck do I make the body?!
Replies (13)
Message 2 of 14
jeff_strater
This is by no means the only way to do this, but for this kind of thing, I tend to go back to this technique:
Jeff Strater
Engineering Director
Message 3 of 14
TrippyLighting
Can you share the .f3d file with that outline(spline)?
Message 4 of 14
hieiswordflame
Here you go. Should have added it to the original post, sorry.
Message 5 of 14
hieiswordflame
So I could basically create the different pipes in segments and then edit them individually?
I feel dumb haha. I'll try.
Message 6 of 14
TrippyLighting
The main body you'd design as one contiguous T-Spline. For the decorations and details you'd use  Jeff's method.
Message 7 of 14
g-andresen
In my point of view, ASPIRE is the better tool for this.
günther
Message 8 of 14
TrippyLighting
günther
It depends what the desired end result is. If a triangulated mesh is OK, I would probably use the real sculpting tools (not T-Spline or Sub-D) in Blender.
Message 9 of 14
hieiswordflame
I had no idea that program existed. Can you import dxf? I'd hate to have to redraw all 5000+ polylines lmao.
Message 10 of 14
hieiswordflame
But it's in sections. And how would I make a continuous tspline?
Message 11 of 14
TrippyLighting
Like this:
Message 12 of 14
hieiswordflame
Whoa! How did you do that?
Message 13 of 14
g-andresen
@hieiswordflame  schrieb:
Can you import dxf?
Yes, this is possible, as is connecting open vectors and cleaning up contours.
günther
Message 14 of 14
TrippyLighting
Here's the start of it. Take your time and be patient 😉
