Project that opens is different from thumbnail
evanp4509U4JZ
evanp4509U4JZ
Really getting tired of this and don't know if I'm doing something or fusion just hates me or there is some other problem. About 2% of the time when I open a file it is different from what it was last time I closed it. I always save before closing as prompted. Usually the problem is that the last couple things I did are missing, ie. cut path modifications, surface additions to facilitate a certain cut process etc.. Often the machining zero has reverted to where it was when originally imported to the project. Doesn't fusion "capture location" on saving?  This last time the entire project is missing nearly half the bodies, visually noticeable when looking at the thumbnail in the far left menu vs what opens in the project, 2 tool paths are missing and the remaining tool paths are unpostable.
Is my computer broken? Is my fusion broken? Am I doing it wrong?
TheCADWhisperer
@evanp4509U4JZ wrote:
... tool paths are missing and the remaining tool paths are unpostable.
You might get better information over here....
https://forums.autodesk.com/t5/fusion-360-manufacture/bd-p/2070
